12-21-2021, 03:29 PM
INSTALL BADGER APP
enter 'androidbuzz.ca/apps/Falcon.apk' in URL field & click go
open 'Chrome' app
(if you don't see it, go to apps and open file browser/file manager/file explorer and navigate to the downloads folder on your android box .. open the falcon.apk and click to install)
(if you don't see open, navigate to the 'Falcon' app in your apps)
Once Falcon is open enter any name you'd like to call this device into the 'Customer' field and press ok
Now you will have to select whichever server you are on out of the list. (If you need this info please contact us)
Once you select your server a window will pop up to log in.
The top field is the 'Username'
The bottom field is for the 'Password'
Enter the information you were supplied with.
Click Ok
If you get an error, go back and double check the spelling of server, username and password
If you were authenticated successfully you will now see the home screen and you are finished.
** PLEASE NOTE - if you logged in to your LIVE TV login, you will not see anything in the 'Movies' or 'Series' sections
Now start watching TV
